SailNet Community - View Single Post - Sailboat without a mast
post #22 of Old 08-29-2012
PorFin
Seņor Member
PorFin's Avatar
Re: Sailboat without a mast
Originally Posted by pedalsteel View Post
Would removing the mast as described have any ill effects on the vessel?? Thanks Al.
Al,
I'll take a stab at giving a concise response:
- If you mean "will removal of the rig permanently damage the boat," then no.
- If you mean "will removal of the rig negatively effect it's seaworthiness," then yes.
- If you mean "will removal negatively effect the boat's value," it certainly will.
The first and third bullets above are pretty much self explanatory.
The middle one's the kicker.
A well designed sailboat's all about bringing opposing forces into balance. Take part of that design away, and the resulting imbalance will require you to make many compromises. I can tell you from personal experience that you'll find a rig-less keel boat to be a handful in even moderate conditions. And don't think that just because you are going to be in near-shore or inland waters you will be immune -- any large body of water with sufficient fetch will develop sea states that need to be respected.
PorFin is offline
