SailNet Community - View Single Post - Electrical propane shut off valve
post #1 of Old 09-01-2012 Thread Starter
marioro12
marioro12's Avatar
Hi I recently added a propane heater on my boat and, as per code, I need to install a second low pressure regulator for propane. I am also installing a second shut off valve and I was wonering if i can run it off the same switch/breaker as the existing one that controls my stove. Or maybe I need to use a different breaker all together!
Using the same one would be easier installation. I was thinking of setting it up in parallel. Any thoughts?
Thank you
marioro12 is offline
