I use my CQR #35 on a Cat 36 and it has held in a 60K wind. It has always reset after turning on the anchor and I have never had trouble on the initial setting. I have used it on a variety of bottoms as well. I bought a dual anchor carrier from a place in Barrie, Ontario for less than $1000, which works fine for CQRs. Check around I'm sure you can find a retrofit roller assembly that will work fine with your CQR. BTW you'll probaly need it for the ROCNA as well.
