SailNet Community - View Single Post - spinnaker size
Thread: spinnaker size
post #5 of Old 09-04-2012
SchockT
SchockT's Avatar
Re: spinnaker size
A
Originally Posted by flo617 View Post
Sorry, I meant that the sock forces to use a slightly shorter sail since it messes up the sail shape if there is not enough clearance on top
That is correct, you need a bit of space for the sock to bunch up. I believe some socks even have a strop or rod built in to them for this purpose.
Make sure you have planned out where you are going to fly the sail from before you size the sail. If you think you might want to use a sprit, make that decision before you order the sail. Once it is built there is no going back!
1979 Santana 30 Tall Rig
Hull#101
SchockT is offline
