SailNet Community - View Single Post - Volvo penta 2002
post #1 of Old 09-05-2012 Thread Starter
Wallace39
Volvo penta 2002
Help I have a Volvo penta 2002 I started the boat yesterday and left it running when I was working the engine was running fine then it lost revs and stalled it will start again if you pull out the stop and resetting the cold start but it will not run at low speed and also very sluggish it is also leaving black soot on the water surface from the exhaust sea water cooled i changed all filters and cleaned fuel pump and diaphram I cut open the rack filter and all seamed clean I have checked fuel lines for leaks and when fuel pump is primed fuel is spurting from the bleed screw any ideas??
Wallace39 is offline
