SailNet Community - View Single Post - Water Cooled Air Conditioners For Sailboats?
post #6 of Old 09-07-2012
TakeFive
TakeFive's Avatar
Re: Water Cooled Air Conditioners For Sailboats?
Raw water reverse cycle A/C is pretty standard. In cold water areas it's possible that you might get enough cooling just from the raw water without a refrigerant compressor to remove the heat.
The Delaware River peaks at around 85 degrees mid-summer, which even makes it difficult for reverse-cycle air conditioners to keep up. The guy who used to have his boat two slips up from me figured out a clever workaround: he hooked up the marina's fresh water system to the intake of his reverse cycle system. Then the marina got the $3000 water bill and went looking for where all the water was going. That's why he no longer has his boat there - he got kicked out.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
