Old 12-11-2001
Wensum Wensum is offline
Wensum is on a distinguished road
Cruising the Cyclades
The Meltemi can be a problem but it needs to be put into perspective. It is a katabatic northerly that sweeps out of the Black Sea down the Aegean and results from high pressure over the Balkans and a low over Anatolia. It usually is stronger on the eastern, Turkish, side than in the west.
Generally it begins in mid-morning, reaches F5-6 in mid-afternoon and abates later. (Rarely it can reach F7+ and blow continuously). Its fearsome reputation is largely historical, but it commands respect.
Unlike moderate gales on the Atlantic coasts, however, the Meltemi comes out of a cloudless sky with brilliant sunshine and superb visibility. In a well found yacht, well reefed down, it provides exhilarating swimsuit sailing. There is little fetch, so no big seas. But the Meltemi does generate short, steep seas which are hard to beat into; a yacht tends to pound on the spot. So it is better to lay off a point or two and ease sheets, making the apparent wavelength longer.
Quite the best conditions to have dolphins playing alongside..... ENJOY!
PS The weather forecasting in the Aegean is now much improved and good info can be obtained at harbour offices. On the net a good site is www.poseidon.ncmr.gr/weather
And don''t leave yourself with a long northerly leg to make at the end of your charter!
