SailNet Community - View Single Post - '98 Hunter 376 Impeller
post #2 of Old 09-08-2012
Re: '98 Hunter 376 Impeller
That's exactly what I did. I could never remove the impeller otherwise. I bought an inspection hatch with a waterproof seal from a chandlery (I think it was by Bomar from West Marine) and cut a hole in the wall through the wall from the head right beside the waterpump/impeller. Raise the engine cover before you make the cut so you don't damage it if you cut too deep. Measure a couple of times before cutting the hole to make sure the hatch is properly aligned with the impeller. It's still hard to change, but at least now it is possible.
finleydc is offline
