SailNet Community - View Single Post - Is ELCI needed if AC only runs to GFCI outlets?
post #4 of Old 09-11-2012 Thread Starter
eko_eko
Re: Is ELCI needed if AC only runs to GFCI outlets?
This is the setup I was trying to describe.
Code:
[a: 30A Shore Power] ------------\
                     [b: 30A Double Pole Breaker]
                 [c: 15A Breaker]     [f: 10A Breaker]
                          |        [g: GFCI outlet on panel]
              [d: GFCI outlet in locker]
                 [e: Battery Charger]
Would adding an ELCI breaker between (a) and (b) -- or replacing (b) with an ELCI breaker -- actually make things safer in this configuration?
As I see it, the places where a ground fault are likely to occur are in (e) and things plugged into (g). Each of which come right after a 5ma RCD.
What would a 30ma RCD between (a) and (b) be protecting me from?
I could see the value in a more complex system containing enough branches to cumulatively exceed 30ma residual current without tripping any individual 5ma GCFI outlet or with any non-GCFI branches.
This is a legitimate question, I'm not trying to be difficult.
1975 Tartan 30 Competition Rig
eko_eko is offline
