Old 09-13-2012
rdw rdw is offline
rdw is on a distinguished road
Re: Dinghy protective cover
Are you talking a cover for it while not in use or chaps to cover when in use. Sailrite has video to make chaps which I successfully followed. The chaps seem to be the way to go. They were not real easy to make but if I can do it you probably can. I used sunbrella and vinyl as directed by Sailrite. I added boat blanket to areas that might rub on something else at times, example rub strip. I also added a few net pockets that have worked well.
