SailNet Community - View Single Post - 4hp outboard motor questions
post #26 of Old 09-14-2012
TakeFive
TakeFive's Avatar
Re: 4hp outboard motor questions
FYI, if the Tohatsu is only available in a 15" shaft length, then that could tip the balance strongly in favor of the Honda, which shows a 20" shaft length in the link I posted above. While your transom may be only 15" high, you want the prop immersed well underwater so you can motor through chop and also if you're heeled over. Even under bare poles, in a heavy blow your boat could heel over and you want the prop underwater in those conditions.
If the Tohatsu is available in 20" length, then I'd consider that over 15".
By the way, the Honda at boats.net (which I linked) is significantly discounted (35% off MSRP).
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
