Old 09-23-2012
svzephyr44 svzephyr44 is offline
Sailboat Reboot
svzephyr44 is on a distinguished road
Send a message via Skype™ to svzephyr44
Re: CCA - Cold Cranking Amps question
Originally Posted by The Sailing Podcast View Post
I hope it is not a problem with the alternator.
David
Before you do anything with the alternator check the drive belt tension. A loose drive belt can make it look like the alternator is failing. This is true much more often in a boat since in a car you are usually just topping off the battery where in a boat you can be recharging from a deeper level. This requires more power into the alternator (the engine drive belt) so it is more likely to slip.
I would just take the battery to a West Marine or Auto Zone (since you were taking it out anyway.) They have a machine that will tell you if the battery is any good for free.
Roger
Current position
Ham: W2ZDB Reboot: WDB8435
Web Site:
Blog:
