SailNet Community - View Single Post - CCA - Cold Cranking Amps question
post #5 of Old 09-23-2012
MedSailor
Closet Powerboater
MedSailor's Avatar
Re: CCA - Cold Cranking Amps question
I agree with pretty much everything Rodger says. Also, I believe the difference between CCA/MCA etc is how many amps they can deliver at a given temperature.
From the interstate website here:Interstate Batteries
MCA:
Marine Cranking Amps - The amount of amps a battery can produce at 32°F.
CCA:
Cold Cranking Amps - The number of amps a battery can deliver for 30 seconds at 0°F and maintain 7.2 volts.
RC:
The amount of minutes a battery can be discharged to 10.5 volts by 25-amp discharge at 80°F.
Amp Hour (Ah or ah):
A unit of measure for a battery’s storage capacity obtained by the amount of amps a battery can be discharged (typically 1.75vpc) multiplied by the amount of hours @ 80F (26.7C) . Most auto/marine and light truck batteries are tested at a 20-hour discharge rate. Example: A 12-volt 100ah rated marine battery means that 5 amps can be discharged for 20 hours at 80°F (26.7C) before falling below 10.5 volts (6 cells X 1.75v)
MedSailor is offline
