SailNet Community - View Single Post - New Boat Search Begins
post #7 of Old 09-23-2012
blt2ski
blt2ski's Avatar
Re: New Boat Search Begins
Sloop,
Not surprised you found the Attalia light and tippy. It only weighs 3000 lbs LESS than the equal sized catalina 30! I weight 2000 less than a Cat 28mk II! So in some sense, yes, lighter boats will be/seem tippier or tender if you will.
With about 33-35% bal/disp, tender would probably apply as well, where that would be closer to 40% if they had/used lead vs iron keels of the same size. Altho I would imagine that with lead, they might make the cord thinner, still using the same wt of material! so in the end, no gain!
As far as interior goes....all depends upon the what you want to see or not see. Not a fan of seeing bolts in the cabin as you describe. But when I refinished my interior, I made easier to find said bolts, so I could replace things easy down the road.
Hopefully you can find what you are looking for! Maybe a smaller Cal in the 30-34' range?!?!?
marty
She drives me boat,
I drives me dinghy!
blt2ski is offline
