SailNet Community - View Single Post - cutlass bearing
Thread: cutlass bearing
post #13 of Old 09-24-2012
Kutter
Re: cutlass bearing
Originally Posted by Gene T View Post
Some comments on cutless replacement. It can be done without removal of the shaft by using a proper puller.
Gene
If it is a more modern bearing bedded on epoxy this will have been a low temperature epoxy which will soften around 70-100C, it can then be slid out as it is not an interference fit, no press or puller required.
Kutter is offline
