SailNet Community - View Single Post - 480 Watts of Solar for the Endeavour...
post #1 of Old 09-25-2012 Thread Starter
Sumner10
Sumner10's Avatar
Location: Utah (House & Macgregor 26 Classic) -- Florida (Endeavour 37)
After installing solar on the Mac....
Macgregor 26S Outside Mods page 33
...and enjoying it so much we wanted to do the same on the Endeavour. Solar Blvd had a sale on 80 watt panels about a year and a half ago for $160 each and we bought some on sale. Of course later they even got cheaper, but panels are like computers....buy them and then don't look at prices any more .
I had some measurements that I'd taken at the boat and designed a frame where...
...4 panels would mount forward behind the boom and over the bimini with 2 more behind them. A slot was left in the middle of the front 4 so that we would be able to see the windex through the bimini window.
Here is a picture at home...
...with the 6 panels in the frame. Next a ....
...wood mount was made to use at the boat to hold the panels in place so that uprights could be made and placed under the frame. Before leaving a number...
...of different type mounting brackets were made to mount the frame for the panels to the cockpit coaming and pushpit rails.
At the boat the .....
..... wood mount was installed in the cockpit and then Ruth and I ....
...reassembled the frame and then ...
...constructed uprights and mounted them with the brackets that had been made at home.
When we left the boat we had one panel installed where the arrow is above and wired it to the junction box under that corner of the frame. Then down to the MPPT charge controller and left that hooked to a battery and a bilge pump. All other electrical was disconnected.
I'll post more when I finish all of the rest of the wiring when we return to the boat.
You can find the whole build and install at the link here....
Endeavour 37 Electrical Mods Index
Sum
Our 37 Endeavour --- Our 26 MacGregor --- Trips With Both
Sumner10 is offline
