SailNet Community - View Single Post - Help me decide - Mooring bitt or cleat?
post #3 of Old 09-25-2012
paulk
paulk's Avatar
Re: Help me decide - Mooring bitt or cleat?
A mooring bitt on a boat that small does not make much sense. It would need to be fairly small, as bitts go, and getting the mooring line around the tight curves could be a hassle. Getting lines off a bitt can also be a hassle, especially when an eager helper puts half hitches in every turn. An 8" cleat is a bit hefty for this size boat, but it would spread the load of dock and mooring lines over a bigger area of the deck than a bitt, which would be better for the structure of the boat. (Don't forget to put in backing blocks.) A cleat would probably be easier to tie off to and uncleat from in general, than a bitt. You may also be able to cushion the cleat with a lifejacket and spread out on the deck. A bitt would stick up that much further and be uncomfortable to lie down on. K.I.S.S.is almost always a good idea on a boat.
paulk is offline
