SailNet Community - View Single Post - Alternator Output Wire
post #3 of Old 09-28-2012 Thread Starter
SVTatia
Re: Alternator Output Wire
Thank you Maine Sail. My plan is to make the Battery Switch a use switch as per your recommendation on “1/BOTH/2/OFF Switches Thoughts & Musings” post – to quote you:
“To make your 1/BOTH/2/OFF a "USE SWITCH" simply:
1- Make your house bank #1, or "primary"
2- Make the start/reserve battery #2 or "back up/secondary"
3- Install an Automatic Combining Relay (VSR) or an Echo Charger to charge bank #2.
4- (Bonus Option) Feed alternator output directly to the house bank.”
What I am trying to accomplish is to wire the alternator/starter directly to the battery, bypassing the switch - making the house bank the engine starting battery and make the charging “always on” with a VSR to the reserve battery.
Since my alternator output and starter share the same cable, can I route this cable that is now starter/alternator directly to the house bank to comply with your item 4 above?
Else I would have to find a way to wire a separate alternator output wire to the battery.
Thanks
SVTatia is offline
