SailNet Community - View Single Post - Fuel Injector Pump leaking
post #17 of Old 09-28-2012
ADwight
Re: Fuel Injector Pump leaking
The pump is pretty much dismantled and in pieces. Found 3 broken springs in 3 of the 4 chambers, and still have the head pieces of one of the plungers still up in the chamber, stuck. Will have to find tiny needle-nosed pliers to get a hold of it and try to pull it out (tweezers don't grab tight enough to get a good hold). Soaking in diesel now. Wanted to give update to those interested. Am thinking that if I can find the proper replacement springs, and if the head pieces of that stuck plunger are not damaged, and if I didn't score or scar the chamber walls removing the parts, and a few other "ifs", then I just might be able to put this thing back together and make it work. Any information on replacement parts or rebuild kits, etc. would certainly be welcome. Thanks.
ADwight is offline
