SailNet Community - View Single Post - Shorter Single Line Reef Line
post #3 of Old 11-26-2006 Thread Starter
dnseal
Living the Dream
Thumbs up Understood
Good Point, however, when reefing I typically turn to wind and adjust/fit without loads. I understand and appreciate your view though. I am mounting a double reef system with the first reef going to the helm station and the 2nd mast mounted as it would most likely require greater attention, balance and if needed. I am opting for the block system to reduce friction, which on Stella shouldn't affect her 450 sq ft too much. By the way She has a very low sail aspet ratio. I was just wondering if there were othe possibilities out there.... thanks again
gil
dnseal is offline
