SailNet Community - View Single Post - Lightning centerboard extraction
post #7 of Old 09-29-2012
CalebD
Tartan 27' owner
CalebD's Avatar
Re: Lightning centerboard extraction
The CB on a Lightning is supposed to weigh <= 130 pounds. ILCA Lightning Plans and Specifications
Probably be easier to extract the CB in shallow water on a calm day. You need to find and remove the pivot pin in the CB trunk.
I'm not sure if this is feasible or not but you could remove the cap of the CB trunk in the cockpit. You might be able to jigger the CB out through the top. I doubt this would work with the boat lying flat in it's trailer though. You'd likely need some wiggle room.
Another thought is to dump the Lightning onto the ground, prop up one side and dig a trench under the CB.
Good luck.
Everybody has one:
CalebD is offline
