SailNet Community - View Single Post - Seller agreed to offer, but set a clause,"no discounts after survey"
post #60 of Old 09-30-2012
Jgbrown
Originally Posted by Minnewaska View Post
jasn, your writeup was very good. However, this is the rub. If you've sold enough boats (and aircraft in my case), you can become suspicious of buyers. Many do try to take advantage and nickle and dime the final purchase price for previously disclosed or very obvious items. If you read around this site, you will see some reportedly experienced buyers actually suggesting you do so.
There is nothing wrong with having a surveyor act as your professional advisor, when the buyer lacks the skill themselves. I know quite a bit about most systems, but I would never trust myself to buy without a surveyor. That is most often the case. It's when the buyer made an offer on a 20 year old boat and begins to ask for it to be returned to near new condition that you aren't dealing with a novice, you're dealing with a lack of common sense.
Here's an example. A surveyor may note that a 20 year old seacock shows corrosion, but remains functional, and note it as recommended maintenance down the road. The seller is going to say, no kidding, you will expect to have plenty of maintenance down the road on a 20 year old boat. Some buyers will try to negotiate a price reduction to replace every seacock on the boat, while the survey did not say they had to be replaced now.
Post survey adjustments should be reserved for either undisclosed or unexpected squawks. If the buyer just doesn't like the overall condition of the boat, when the surveyor tells them that they will have lots of maintenance after they buy it, then the expected outcome should be to walk away.
I bought a boat that was advertised literally as an "11 out of 10". Unless that is what the offer says, you can't negotiate for it later.
Trusting a costly(2x going rate) pre purchase surveyor is how I got where I am today, with 4 months in and yet to even sail around the bay.
I'll be replacing my totally non functioning seacocks next haul out. At least I'm learning a lot. I knew project boats like vehicles are usually a losing battle unless it's just sitting neglect, not decades of ignored maintenance.
I bought a project misrepresented as a 9/10 (all major work done in preparation for cruising south, new engine, sail etc just needing exterior trim sorted, and minor cosmetics).
Now that I've spent the same again as the high sale price, she's almost what I thought I was buying in the first place.
Next buyer will get what I thought I was getting, and at the same price I paid.
Sent from my SGH-I747M using Tapatalk
Jgbrown is offline
