SailNet Community - View Single Post - Deck Grizzly grip non skid paint ..don't waste a nickel it's a fraud
post #5 of Old 09-30-2012
Capt. Gary Randall
Capt. Gary Randall's Avatar
Re: Deck Grizzly grip non skid paint ..don't waste a nickel it's a fraud
Hopefully this will help you,whenever I'm using two different manufacturers of epoxy I always use a barrier coat in between there are so many different types of epoxy primers that a barrier coat is absolutely required when not using the manufacturers suggested Primer. Think about it, you have 50-50 at 8to1 and many other epoxie mixes.I have used the same product many times it also must be applied in thinned coats according to temperature and humidity.never apply a cold mix overall Hotmix . Example: you can epoxy over polyester resin but you cannot put polyester resin over the epoxy.that is the best analogy I can come up with.... hopefully this will help you... CaptG
Capt. Gary Randall is offline
