SailNet Community - View Single Post - Universal M18 - stopping using throttle push back
post #4 of Old 10-01-2012
MarkSF
Re: Universal M18 - stopping using throttle push back
When you push against the throttle to stop the engine, you are doing so against quite a powerful spring. You may have to push harder than you have so far. Presumably it's designed thus to prevent you from accidentally stopping the engine.
There is a distinct stop at the idle position, then it will move further against the spring. (if it's adjusted properly!). I have to push hard on the lever, so I would not expect you to be able to move the arm at the engine by hand.
When I got my Universal I didn't know this and couldn't figure out how to stop the engine!
MarkSF is offline
