SailNet Community - View Single Post - Unable to find a part.
post #6 of Old 10-03-2012
svHyLyte
Old as Dirt!
svHyLyte's Avatar
Re: Unable to find a part.
Dale--
There is a temporary fix if the part isn't leaking. Separate the shell halves and insert a partially inflated balloon that's had the umbilical heat sealed in something like a Food Saver, then close the the thing up again. Your pressure pump will fill the cylinder and partially compress the balloon until the pump reaches the cutoff pressure. So long as the cylinder itself doesn't leak and the cutoff pressure isn't too great, you'll be surprised at how long the fix lasts (carry spare balloons). BTDT...
FWIW...
svHyLyte is offline
