SailNet Community - View Single Post - 35 year old standing rigging - but rigger says it's ok
post #60 of Old 10-04-2012
casey1999
casey1999's Avatar
Re: 35 year old standing rigging - but rigger says it's ok
some more interesting information:
Wire Cable: Un-stepping the rig is also the time to consider renewals and/or
replacements associated with rigging wire cycles. A rigging wire cycle is a
recommended replacement/renewal duty life cycle interval. Industry sources
consulted provided the following general guidelines for replacement/renewal
subject to regular detailed visual examinations, environmental conditions and
regular maintenance.
Change end fittings every 2nd cycle or 12 years;
Change wires every cycle or 6 years;
Change chain plates every 3rd cycle or 18 years.
* Source: Morrelli and Melvin, Gold Coast Yachts, SECO South (Navtec)
…While rod will generally last longer than wire, re-heading is usually recommended after disassembly or as specified by the manufacturer.
http://www.pcmarinesurveys.com/USCG%...inspection.pdf
http://www.offsoundings.com/WEB%20PDF/SV_KIELE_V.pdf
Paulo,
Thanks for the additional information. I remeber these demastings as I was living in Hawaii at the time. I had not seen the CG report on the Kiele, that is very interesting.
casey1999 is offline
