SailNet Community - View Single Post - Chartplotter died, time to upgrade?
post #10 of Old 10-05-2012
Minnewaska
Re: Chartplotter died, time to upgrade?
If you can afford it, definitely upgrade. First, you will be grinning ear to ear for an entire season when you see the difference. Seriously. Second, it is one of the best ways to improve the value of your boat. However, not by the full investment. As a generality, your current stuff is literally worth zero. New models are worth about half what you pay for them, if you thought to sell or refinance your boat. If that sounds bad, consider that most anything else you spend on your boat is worth less in value, typically because you are just fixing stuff that isn't supposed to be broken or fully worn. Electronics are somewhat optional, however, on larger boats, modern electronics can be an expectation.
As a rule, I prefer to keep all systems from the same manufacturer: plotters, radar, autopilots, etc, etc. Whatever needs to talk to each other, that is. It keeps them from pointing figures at the other brand in the link, if and when you have an issue.
Jeanneau 54DS
Minnewaska is offline
