SailNet Community - View Single Post - Advice on removing snapped s/s bolts from alu block
post #19 of Old 10-05-2012
tommays
tommays's Avatar
Re: Advice on removing snapped s/s bolts from alu block
You pretty much screwed yourself not using heat and patience in the initial tear down don't screw your self up even worse learning to drill out small SS bolts on something that will become JUNK if you get wrong as there is NO room for error
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
