SailNet Community - View Single Post - Advice on removing snapped s/s bolts from alu block
post #26 of Old 10-05-2012
tommays
tommays's Avatar
Re: Advice on removing snapped s/s bolts from alu block
One of the issues with helicoils in a wet area of a block is well they LEAK
The second issue is the helicoil tap/drill is one full size over the old bolt hole and IF there is enough wall there to do it as the water passages are pretty tight
1970 Cal 29 Sea Fever
1981 J24 Tangent 2930
Tommays
Northport NY
tommays is offline
