SailNet Community - View Single Post - Keel bolt torque values ????
post #5 of Old 10-05-2012 Thread Starter
anerussis
anerussis's Avatar
Re: Keel bolt torque values ????
Originally Posted by Sabreman View Post
One of the routine maintenance chores that I do in spring is to tighten keel bolts. I use a 3/4" socket wrench with a 1 1/2" socket and a pipe extender. Then I torque as much as I can. It's a keel. They're big honkin' bolts. As much torque as I can apply is what I want.
With that said, Sabre recommends 90 ft lbs torque.
According to the chart 1 1/2" socket is for a 1" bolt - torque to 350 ft lbs - if you tighten past that would there not be a danger of pulling the bolts from the keel or crushing the fiberglass?
Years from now you will be more disappointed by the things you didn't do than the ones you did do.
~Mark Twain
anerussis is offline
