SailNet Community - View Single Post - Keel bolt torque values ????
post #8 of Old 10-06-2012
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Re: Keel bolt torque values ????
Originally Posted by Sabreman View Post
One of the routine maintenance chores that I do in spring is to tighten keel bolts. I use a 3/4" socket wrench with a 1 1/2" socket and a pipe extender. Then I torque as much as I can. It's a keel. They're big honkin' bolts. As much torque as I can apply is what I want.
With that said, Sabre recommends 90 ft lbs torque.
"Give me a lever and a place to stand and I will move the world".
There is a reason torque wrenches were invented - you can exert a HUGE amount of force when you put a pipe extension on a wrench, enough to shear the threads or snap the stud. Stainless steel is also easily galled when too much torque is applied. I can quite easily apply over 100 Ft. Lbs with one hand and a 1/2" drive torque wrench.
Use a torque wrench and tighten the nuts to the torque specified for that size stud. Even a cheap torque wrench is going to be a LOT more accurate than "a piece of pipe and as hard as I can".
SloopJonB is offline
