SailNet Community - View Single Post - Battery capacity - Peukert stuff
post #3 of Old 10-07-2012 Thread Starter
bhcva
Re: Battery capacity - Peukert stuff
"That's simply linear -- bigger bank, bigger time remaining."
True, but that's the question...is it really linear if multiples of batteries are coupled. The P equation has five inputs as you know - the only one that could change if I enlarge the bank is the available amp hours. If I double up batteries to double the amp hours available I could just double the minutes available as computed from the single battery configuration; or, I could use the now doubled available amp hours in the P equation and I will see that the available minutes at any amperage more than doubles by something on the order of 10%. Which way is correct?
"Solitude" Caliber 40
Ches Bay
bhcva is offline
