I need to make a decision to buy 300' of chain or 300' of brait. Anchoring will be on Lake Champlain year 1 and Atlantic coast (Cape Cod, points north) year 2. Anchors to be used will include Delta Fastset, CQR and a Bruce. The boat is a Passport 40 and I have yet to decide on a new windlass. We're only going to have the boat for two years which is why I'm cringing at spending $600-$1000 for chain. With chafe protectors, what are the current thoughts on the durability and breaking strength of 5/8" brait vs. 3/8" or 5/16" chain? I'd use 40'-50' of chain plus the brait - not all brait. I'd love to hear some thoughts. Also, what about 3/8" vs. 5/16" chain on this boat (22,000 lb displacement)?
I think this discussion ranks right up there with the best keel typs that every sailor argues over, but, here is my opinion(s) and what I do:
I carry both.
I carry 250' all chain and use this as my primary. You can tie a line from the chain and cleat it off as a snubber to reduce the shock load. I am a big fan of chain for many reasons: 1) no chafe on rocks or coral, 2) excellent holding, 3) you "can" use less rode if the situation requires it.
I have come into many anchorages where the other sailboats ran all chain at about 5:1. If you have a "rope" rode, this scope could cause you to drag. If you put out 7:1, you might swing into another boat. However, if you come into an anchorage where the boats are swinging at 7:1, you can always let out more rode.
I also like having what I call a lunch hook and a rope rode for light days and/or afternoon stops. It is easier to work and easier on the fingers. I do have a windless, but it does not strain as much with the rope (though I have to keep pressure on the back side).
If you can, carry both. You should carry two hooks anyway with a differnt anchor for different bottoms.
I have had an all-chain anchor rode in the past that gave excellent service.
The drawbacks to chain are associated with its weight. It will put a lot of it in the forward end of the boat and probably above the CG. It is also mighty heavy to recover and you will most likely require a windlass.
Lately, I have switched to a generous length of chain (perhaps equal to waterline length) and nylon for the balance. That puts the chain in contact with the bottom where it will resist abrasion, and the nylon stretches under load.
One last point. Chain eliminates the problem of chafe, while nylon requires watchfulness and careful application of chafing gear.
I can't imagine that a soft, high-snag line is going to serve you very well on anything but sand or mud. Any rocks or tree detrius on the bottom are going to tear the line up. Three-strand doesn't snag because the strands have a smooth aggregate surface. Also, nylon tends to harden with age and exposure to salt water, which would eliminate any flexibility advantage that new brait might have. And if you buy dacron brait, you lose the stretch factor that makes 3 strand nylon such an excellent snubber.
In my opinion, conservative decisions with regard to ground tackle are never money wasted. How much will you have saved when the boat drags onto the rocks?
On my Morgan 30 (10,500 lb dsp.) I run a 27 lb CQR with 100 feet of 5/16 inch chain backed by 200 feet of 5/8 inch three strand nylon. I found that I never put out less than 70 or 80 feet of rode, regardless, and so I figure I might as well put out 120 feet - the chain plus 20 feet of nylon as a snubber. This works well for me in LI Sound, where most anchorages are 10 to 20 feet deep (and rocky.) In the event I need to reduce scope, (never happens, even in crowded anchorages) I do carry a couple of nylon snubbers with chain hooks. Is this overkill? Maybe. But I sleep well, even in the squalls.
I did save some money by buying two 50 foot shots of chain at a consignment store and shackling them together. I don't have a windlass and I wire the shackles closed with monel seizing wire, so shackles in-line aren't a problem for me.
It's tough.. I want all chain and I know many of the advantages. My wife is having a problem with me spending 5 to 10 boat units on chunks of metal, but I get to make the final decision. I was just hoping - praying - someone would pipe up with "These days, a brait rode is just as good as an all chain rode!" Oh well. I know what I gots to do. I'm just not looking forward to telling the wife.
With regards to the other question... 3/8" chain vs. 5/16" chain for an all chain rode? Any thoughts on that?
Labatt...for your proposed cruising grounds and anchors...I don''t think chain or brait is needed. I would get 3 strand nylon as it holds up better and 50' of 3/8 BBB or HT chain. Chafe is not a big issue up north. Brait is easy to handle but expensive and 3 strand is long proven and will easily hold up for 2 years. Get a windlass that can handle rope & chain and enjoy more Molsen with the money you save!
Decide on your windlass before buying your chain/size. You can get a windlass for either, but my reccomendation is to buy them in synch. If you did not like the price of the chain, you really won't like the price of a 3/8 chain windlass. Of course, you can always tell the wife what I told mine: You are responsible for weighing anchor! She will be much more amenable to anything that will save her back (and your marraige).
I think the 5/16 would be fine. That is what I bought for mine. I have a Catalina 400, about 22000 lbs before the pots and pans. I will warn you though, I paid for the solid gold chain with studded diamonds, but all they sent me was this crappy galvanized chain (Grade 70, Hot Dip Galvanized High Test).
Enjoy pulling out the credit card. But remember this: the real fun won't start until you try to get 44 tons of chain down the dock in a push cart and try not to let it fall in the water or blow out your back!
Cam from his name Labatt I think he will enjoy a Labatt Blue or Bleu rather than a Molson. I have to agree though that all chain rode is a bit of over kill not to mention a helluva lot of extra weight and expense
As others have said, all chain is the way to go. I heartily agree. You can save a bit of money by buying less chain....200' or 250' is plenty, IMO.
Re: type and sizing, suggest strongly you go with 5/16" G40 (high test) chain. Pay special attention to the SHACKLES used to connect the chain to the anchor. Most shackles you see in the chandleries are not adequate; they are not as strong as the chain, and are the weakest link. Good shackles, made of alloy, are pricey but you can find them online for reasonable prices. Columbus-Mackinnon and Crosby both make very strong alloy anchor shackles. Buy the largest which you can fit (I believe 3/8" shackles will fit 5/16" G40 chain, and use a 7/16" or 1/2" shackle to link that to the anchor.
With an all-chain rode, it's a very good idea to use one or two bridles made of nylon line with a chain hook on the end. These are used after the anchor has been set to help absorb shock loads and to transfer the anchor load from the windlass to cleats on the foredeck. They also help keep the boat from "sailing about" at anchor. For your boat, 1/2" 3-strand nylon about 30 feet long would be sufficient for these.
You mentioned that you only expect to have your boat for 2 years, so price is a consideration. I understand that, but suggest you consider resale value also. A Passport 40 is a very high quality cruising boat, with a fine pedigree and much sought after if in good condition. If I were in the market for one and spotted anything other than first class ground tackle and windlass gear, it would raise alarms in my mind about how the rest of the boat had been outfitted and cared for.
For this, and for the very practical reasons noted above (peace of mine, keeping the Admiral happy, etc.), I would not skimp on ground tackle and windlass gear.
Bill...I have one all chain rode and one rope/chain so I understand the need for good tackle and the advantages of each. Given his limited proposed cruising grounds...what anchoring advantage do you feel all chain provides? (I understand the resale value argument).
My own feeling is that a combination rode with sufficient chain up front is a better system for the shock loads of a good blow to KEEP you anchored when the catenary effect of all chain is lost. I know that the snubbers provide some slack but not to the same effect as an extended nylon rode. In coral or other high chafe environments all chain is my choice as well.
Labatt...you mention 3 anchors but are only looking for input on one rode. Why is that? What does the boat have already?
Anchors: Bruce 45#; CQR 35#; Fortress 23#
Rode: 150' 5/16" high test chain; 200' 3/4" nylon; 150' 3/4" nylon
I'm guessing the bruce was the primary I'm not a lover of the Bruce... I'm thinking of making it my backup and buying a big Delta Fastset which I had excellent luck with on my prior boat (albeit much smaller). I'm debating 50ft of chain + 300ft of line, or 300ft of chain + 50ft of line. I spent many days anchored in 60 ft. of water last summer - I want the flexibility to anchor wherever I want, and away from people who may not have as much rode. Lake Champlain is a very deep lake, all the way to the edge, although others have pointed out to me that there are plenty of anchorages in the 20'-30' range. I'm sure there are, but I didn't find them in the one season I was on the lake. I will definitely be looking for them this year!
The following year we plan to bring our boat to Cape Cod (although I'm wondering if I'll be able to get a slip or mooring within a reasonable distance of my house near Albany NY i.e. no more than 3 hours away). We'll be cruising throughout Cape Cod and the Maine coast.
Then we'll be selling our boat and moving up to a 50'-55'. I should say moving onto since we'll be spending the next 18 months living on it.
I do not expect to be anchoring THIS boat anywhere that coral exists. We will be anchoring it in rock, sand and mud.
I'll be doing a complete inventory of the boat in a couple of weeks and I plan to pull all of the chain and rode out of the locker to check its condition. I have a pricing request in to Defender right now for a 300' chain + 50' brait combo. I don't even want to guess what shipping costs will be! I should see about buying it local - it will be the one time when tax will be less than shipping!
And with regards to beer, I will drink a Labatt's when visiting Canada, but I'm much more of a Sam Smith Nut Brown or Oatmeal Stout guy myself, served warm and in a pint glass I'd still much prefer a Planter's Punch from American Yacht Club in Rye, NY any day.
Labatt... I agree with you on the anchors... a #55 Delta (or equivilent Spade or Rocna) would be a much safer primary. Given your existing rodes...why not combine the 150 chain and 150 nylon into one rode then add 50 ft. of chain to the other nylon and run the Bruce off of that? 150' of chain will give you an all chain rode in anything less than 30' and no need for a snubber in anything over that!
Chain has some advantages over nylon, but also has some serious disadvantages.
Advantages:
Chafe resistance, catenary curve,
Disadvantages:
Weight, shock loading of ground tackle, generally requires a windlass,
BTW, the catenary curve provided by chain is negated in high wind conditions, when both chain and nylon rodes are going to be heavily loaded and essentially straightened out.
Depending on your boat, it may make more sense to go with a combination rode, with about 30-60' of chain to give the rode chafe resistance, and then the rest of three-strand nylon, for the shock absorbtion and lower weight.
The 55# Delta is exactly what I was thinking. Also, not a bad idea to combine rodes. When we go down to work on the boat in a couple of weeks I'll look at the viability of that. Defender wants $760 for 300' of 5/16" BBB connected to 50' of 5/8" brait with shackle and splice, but not including shipping (which will probably be $150 or so, by truck). My wife and I were just trying to figure out how we would get it to the boat!
Related Threads
1.7M posts
173.8K members
Since 1990
