SailNet Community - View Single Post - Galley counter top material
post #45 of Old 10-08-2012
Minnewaska
Re: Galley counter top material
Originally Posted by MysticGringo View Post
Has anybody tried a liquid glass like product? It's the clear epoxy you see on bar and table tops at restaurants.....
I applied this to a bar top in my rec room at a previous house. It is easily scratched. Coasters, placemats, etc were needed religiously. If you look at one in a bar, they are hazed over by the scratching, although, don't look too bad. I'm also certain they can't take much heat.
Installation is probably the tougher part, unless you can remove your counter tops from the boat. They need to be perfectly level, and I mean perfectly. The stuff seeks a level and the slightest imperfection will be noticed over the length of a counter. No way any of our boats are that level. The advantage, however, is that the fids will provide a natural barrier to hold the stuff in place. Letting it run over the edge is very difficult to get right.
Jeanneau 54DS
Minnewaska is offline
