SailNet Community - View Single Post - Yanmar not starting
post #7 of Old 10-08-2012
DrB
Re: Yanmar not starting
ltgoshen
Originally Posted by doug1957 View Post
Thanks all. The exhaust riser blew out before the mixing elbow, so that explains part of the problem. Should have made sure (asked) the PO if he cleaned the elbow regularly. Water in the combustion chambers has come to mind.
Yo Doug Vinigar twice a year thru the engine will help beat down the build up.
1)Start the engine,
2) Put a gal on Vinigar in somthing you can fit your suction hose into.
3) take your suction side hose off the water strainer and let it draw the vinigar thru your engine.
4) when all the vinigar has been pulled thru the engine, hook your hose back to the raw-water strainer.
It should help some. You will still need to do a good exhaust riser cleaning once a year. Good luck. I have a 2GM 13 yanmar and Its a great little engine. A little maintenance and they will last a lifetime.
Are you saying that sucking the vinegar through the engine in a single pass is enough residence time to clean the exhaust riser or do you need to start the motor, suck the vinegar in, shut the motor down, wait 10 minutes or so for the vinegar to break up the scale, and then blow the vinegar out on the restart? I have also heard that you can use oxalic acid diluted about 1:1.
DrB
If you liked my advice/response, give me some rep points. If you didn't......well what do you expect, it was free.
DrB is offline
