SailNet Community - View Single Post - Hallberg Rassy Rasmus Fuel Tank Leakage
post #16 of Old 10-08-2012
hgv50
Re: Hallberg Rassy Rasmus Fuel Tank Leakage
I don't know about the Monsun, but on the Rasmus there's a tank cover which you can take off. Once out, it's a quick job to drill a hole in the cover and fit a large thru-hull with threaded cap, then replace. We did and there's a good 12V pump (with which you easily empty the tank - about 3 gallons a minute) that you can insert into the tank via the thru-hull; Rule IL500PK.
hgv50 is offline
