SailNet Community - View Single Post - Sending GX2150 AIS NMEA data to chart plotter over Bluetooth
post #21 of Old 10-09-2012 Thread Starter
TakeFive
TakeFive's Avatar
Re: Sending GX2150 AIS NMEA data to chart plotter over Bluetooth
Originally Posted by audeojude View Post
Thanks for the quick reply. On my netbook It does run really slow because of all the maps that are loaded. sometimes 30 or 40 seconds to go from map to map. My main computer is a lot faster though and at the longest I have a 4 or 5 second delay. Most of the time it is pretty seamless. Didn't know if that was normal or I could get even more speed out of it if I had misconfigured it.
scott
It does not take nearly that long on my netbook. After you reduce the number of charts, you should force a full database rebuild. If that does not work, you should check the OpenCPN section of CruisersForum for support from the authors.
2001 Catalina 34MkII Breakin' Away (at Rock Hall Landing Marina)
PO of 1998 Catalina 250WK Take Five (new owners relocated to Baltimore's Inner Harbor)
1991 17' Trophy (Lake Wallenpaupack)
TakeFive is offline
