SailNet Community - View Single Post - Staysail: Purpose and trimming
post #5 of Old 10-11-2012
jimjazzdad
Bluenoser
jimjazzdad's Avatar
Post Re: Staysail: Purpose and trimming
Originally Posted by daledog View Post
yeah...I'd also like to hear when and how to use them. And a storm jib would be flown on the foresail halyard correct? And Seaduction, you reposition the staysail back along a shroud? Can you clarify what you mean? is it to the side or in front of the mast? I had both on my Cal and didn't use either.
Is it a cutter rig that has a staysail?
I sail a 1983 Hunter 37 Cutter. My staysail, and its forestay, are permanently installed. My furling jib at the bow is a "Yankee" - very high clew (10 -12' above the deck) and MUCH smaller than a genoa. So my staysail and jib work together, with the staysail "filling in the gap" below the Yankee jib. This is a conventional cutter setup - both sails are intended to be flown simultaneously. My 1st reef is to roller furl the Yankee and use the staysail as my sole headsail. Because the staysail is self-tacking on my boat, going to weather in heavy wind requires little effort. I love the rig, although it doesn't go to weather quite as well as a big genoa in lighter winds.
If you use a big genoa normally, and only intend to use the staysail in heavier winds, removing and storing the inner forestay for the staysail somewhere back by the shrouds is probably a good idea, making tacking the genny easier and saving on wear & tear...
jimjazzdad is offline
