SailNet Community - View Single Post - Vancouver 27 vs Albin Vega 27
post #12 of Old 10-11-2012
SloopJonB
Senior Moment Member
SloopJonB's Avatar
Re: Vancouver 27 vs Albin Vega 27
Originally Posted by copacabana View Post
The Vancouver 27, from a quick search, displaces 8,960 lbs and the Vega 5,148 lbs. They are both small boats and I would expect very similar costs to maintain either. I don't see why the Vancouver would cost as much as a 32ft or 34ft boat. In both the case of the Vancouver and the Vega one would expect simple systems. There just isn't the space to start loading on a lot of complex systems on a boat this size. Another advantage of the Vancouver with its higher displacement is that it is likely able to carry more weight in supplies before its sailing ability is compromised.
The displacement of the Van 27 is nearly double that of the Albin. Boat expenses go up more in relation to displacement than LOA. These days 10K Lbs is pretty typical for 32'-34' boats so I would expect the size of gear needed and so forth to be similar to the Van 27.
SloopJonB is offline
