SailNet Community - View Single Post - 1984 c&c 35-3
Thread: 1984 c&c 35-3
post #7 of Old 10-11-2012
chef2sail
chef2sail's Avatar
Re: 1984 c&c 35-3
Bubblehead...whats the name of it. Never heard my boat refered to as swanky ( I lkust have too many things hanging off it now- Radar Pole, Davitd, TC antannae, Radar.), but shes fast, Hows does your place in your races? Against what?
Hillenme-
Mine is cored above and below the waterline not below. Every boat is different in terms of water/ moisture. Many boats are cored above the waterline. We have had absolutely no water or moisture intrude in the core or wettness at all. You have to take the correct precautions when putting thru hulls in or deck equipment. After drilling/ boring your hole you ferret out the basla ( end grain in C&C) in the space between the two gelcoat layers. I go back 1/2 inch around the whole diamater. Then you fill that with fiberglass/ epoxy. If you get a ding down to you core you follow the same procedure. I test the wetness with a moisture meter every couple months especially around thru hulls and anything that has bedding ( Hatches , nicrovent, clutches etc.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
