SailNet Community - View Single Post - slightly soft floor remedies
post #21 of Old 10-12-2012
eherlihy
Learning the HARD way...
eherlihy's Avatar
Re: slightly soft floor remedies
See Boulter Plywood in Sommerville, MA
Teak & Holly
Genuine Burmese teak plywood with the appearance of a traditional deck planking:
2 3/8” wide teak,” wide holly
1.1mm thick teak face before sanding
Tropical hardwood core.
1/4" stock is a .9mm face veneer.
-----------------1/4"-------1/2"--------3/4"
4 x 8 -----------215.00-----235.00----275.00
4 x 4 or 2 x 8----130.00-----145.00----165.00
Weight per 4 x 8--25 Lbs-----48 Lbs----72 Lbs
Teak & Holly Plastic Laminate 4' x 8' x 1/2" $275.00 per sheet 2 3/8” wide teak,” wide holly
Teak & Holly Plastic Laminate 4' x 8' x veneer $225.00 per sheet 2 3/8” wide teak,” wide holly
Exact quotations on all products and delivery options can be obtained by:
Phone (888) - 9 LUMBER * (888) 958-6237
No affiliation - just trying to help out.
Last edited by eherlihy; 10-12-2012 at 04:04 PM. Reason: had to edit the quote to make the formatting work
eherlihy is offline
