SailNet Community - View Single Post - Im buying a big boat! But i have never sailed
post #110 of Old 10-12-2012
cookwithgas's Avatar
Originally Posted by copacabana View Post
The real challenge is learning all about your boat. This will take a much longer time, as much as a year or more, depending on how interested you are in how things work. It's really worthwhile going over every hose (change them while you're at it), wire, fuel line, through-hull, pump, the rig, line, sheet, block etc. You will need to know how everything works. When you really know everything on your boat you'll be able to relax, because you'll know how to fix or replace just about everything.
Finally, welcome to Sailnet! You'll find that you'll get a lot of good advice when it comes to sorting out the bugs on your new boat.
Well said Copa!
If you haven't already, you should discover "ZAMM" - Find a copy of "Zen and the Art of Motorcycle Maintenance" and read it. It is completely appropriate for a sailboat owner. Especially a new owner.
Take care,
Scott in New Orleans
cookwithgas is offline
