SailNet Community - View Single Post - Question for those who sail cutters
post #3 of Old 10-12-2012
jrd22
Courtney the Dancer
jrd22's Avatar
Re: Question for those who sail cutters
Some have more room between the stays than others so it can vary as to the PITA factor. True cutters generally have a wider slot than a cutter rigged sloop like I have so I've found them easier in most cases. What I do is if I am sailing upwind, or even a beam reach, I'll fly the staysail as well as the genny. When I tack I'll leave the staysail sheeted tight and release the genny sheet at the normal time. This allows the genoa to slide along the "wall" created by the staysail and slide through the slot without any hangups. As soon as it's clear I tack the staysail. Dead down wind can be interesting, but in light wind I can usually get the genny to go through OK, in stronger winds I furl it in most of the way and then let it out on the other side. You get used to to it, but that's why you don't see many cutters racing:-))
John
SV Laurie Anne
1988 Brewer 40 Pilothouse
jrd22 is offline
