SailNet Community - View Single Post - Replacing lead Keel bolts
post #2 of Old 10-13-2012
Gene T
Gene T's Avatar
Re: Replacing lead Keel bolts
I believe I would drill a new hole for the new stud. Then drill a large hole in the side of the keel to meet the end of the first hole to put a nut/washer on. Drop in some threaded rod, put a nut on the bottom, one on the top and torque it down. I would probably try to remove the old ones first but that may be more trouble than it is worth.
Gene
Currently in Long Beach, CA
Gene T is offline
