SailNet Community - View Single Post - Buying a 30-40 year old boat - your opinions
post #15 of Old 10-13-2012
chef2sail
chef2sail's Avatar
Re: Buying a 30-40 year old boat - your opinions
Nothing wrong with balsa below the waterline as long as there are no intrusion already. The balsa core actually lends to the boats stiffness and structural integrity. If taken care of with the proper treatment of the thru hulls when they were bedded in your should not see any difference in moisture readings between balsa cored/ foam cored/ no cored boats. You are eliminating many fine boats here such as Tartans, Sabres etch
Our boat has end grain balsa which has been correctly handled and it gives the boat adde structure you don't find on similarly sized boats. The thru hulls are placed in areas where there is only the epoxy and the coring removed to prevent water intrusion.I my opinion this should not be a disqualifier or you will look past many fine designed and made boats
Anyplace thru hulls or equipment is placed thru laminate wether above or below the waterline a proper procedure must be followed to prevent water intrusion.
Dave
___________________________
C&C 35 MKIII Hull # 76
Parkville, Maryland
(photos by Joe McCary)
Our blog-
chef2sail is online now
