SailNet Community - View Single Post - Replacing lead Keel bolts
post #8 of Old 10-13-2012
misfits
Re: Replacing lead Keel bolts
Some people will grind out a pocket on one side of the keel so you can put a bigass washer & nut on a piece of s.s. rod & crank it down from inside the bilge. Then you just fill & fair the keel pocket you created with epoxy.
This works if you need to repair a keel bolt or two. Sounds like in your case the only thing holding the keel on is the 5200 it got bedded in 33 years ago.
I'm not happy unless I'm complaining about something.
I'm having a very good day!
misfits is offline
