Not normal. What happens in reverse? Could be, in order of severity: something fouled on the
propeller, spark plug wires on wrong spark plugs, badly misaligned timing, loose zinc on the shaft near
propeller (happened to me once), loose
propeller, loose coupling between shaft and engine, misaligned engine causing shaft wobble, bent shaft, broken transmission.
When hearing hooves, think horses before zebras.
