SailNet Community - View Single Post - Replacing lead Keel bolts
post #15 of Old 10-14-2012 Thread Starter
cousineddy
Re: Replacing lead Keel bolts
Wowsa Eherlihy! What a surprise? How would you ever know there was a problem? Those bolts look fine!! I would have chalked that seem up to normal flexing!
I cut the 5200 away, the keel dropped a bit. See Pics. I am thinking that I will install 8 stainless 1/2-13 hanger bolts. Currently, there are six 1/2-13 studs. I was thinking maybe I should add two 5/8 window bolts in addition. Not really sure if that is necessary. Clamp force on these hangers is 9600 lbs.
It looks like the studs are in good shape up to the bilge. In the bilge is where the corrosion occured. This boat must have had a wet bilge most of its life.
cousineddy is offline
