SailNet Community - View Single Post - Battery charging
post #30 of Old 11-29-2006
btrayfors
Thanks for that clarification, Dave. Lotsa folks don't discriminate between measured voltages UNDER LOAD vs. NO LOAD or no connections. Also, presumably, the charts for batteries under load refer to a 20-hour load only.
One other item: an hour or so isn't enough for a recently charged battery to lose its "float charge" and get down to 12.6 volts or so. Many batteries will hold a higher voltage for much longer. In my experience, 24 or even 48 hours is a safer interval to give a more accurate indication.
Note also that gells and AGMs exhibit higher voltages; those cited above are for flooded batteries.
Bill
btrayfors is offline
