SailNet Community - View Single Post - Air Head Composting Toilet or Similar Mfg.
post #20 of Old 10-16-2012
eherlihy
Learning the HARD way...
eherlihy's Avatar
Re: Air Head Composting Toilet or Similar Mfg.
Because Chrisncate did not reply to this thread, here is what he (they) said in another thread about the composting head;
Oh, and we hate the composting head. Totally hate it. Everything else seems to be alright, except for filthy marina heads which we hate almost as much as the composting head. I can't wait to re install a head and illegally pump out overboard each and every time I go to the bathroom. What a joy that'll be..
and...
Can you give an assessment of the composting head? Strengths? Weaknesses? Opportunities? Threats?
My opinion is that they are moderately unsanitary but probably doable on a medium to large boat with hot water on tap - gross and way too "up close" on a small boat with no hot water on tap.
The hot water is easy to live without, a composting head 1.5 feet from where you sleep and lay your head is .. bad. Keep in mind we are on a SMALL small boat, an A 30 isn't like a Catalina 30, it's real personal and up close in here.
Example: I am sleeping in the V, and suppose the Admiral has to pee (or god forbid, pinch a coil) - well, she's right there, hi! Some things are just things you need to do more than three feet from another human. And the coffee filters... oh the coffee filters..
We have a small boat.
EDIT: I should note the difference in space that the Natures Head takes up as compared to her old traditional head. The N/H is tall, very tall and it makes a huge difference in our small head area. It takes up a lot of area and it's way high. It makes a difference. The old head enabled the bathroom area to be closed off and private when in use, the N/H does not allow this on our boat due to the logistics of the thing from the perspective of the V berth. It still closes off from the salon, just not the V.
and ...
I think they might be ok to good on a bigger boat, a small boat not so much. I guess the truth about heads is nothing can compare to a house toilet. I have yet to encounter a marine head I find acceptable. You either hold it all in a gross smelly holding tank, or you try to ferment it in a composting head, or you pump overboard illegally for the least amount of fuss and hope you don't get caught.
THESE ARE NOT NECESSARILY MY VIEWS. Chrisncate lived with a composting head on their boat, so I defer to their experience.
eherlihy is offline
